DaveJL
136
Belfast
Hi guys,
Not sure if this is the correct forum, but can anyone from Northern Ireland (Belfast/County Down area) know of any good VAG specialists for servicing?
Dave
Ah should have included that!
I've a K1 and looking for a full service and brake pad replacement. There are a few good garages in my area but wanted to know there are any VAG specialists worth looking at.
Dave
If you remember a place Ai autosports that used to build evos etc, the owner jonny now works from home, i got my car back from him monday after getting the timing belt changed. His overheads halfed so hes cut his labour charges in half, £75 labour for my timing belt/water pump change
If you use the rms forum all the members will highly recommend him
How much would stage one and the intake set me back?
I'll check out rms about Jonny, thanks for the heads up!
Hes called AIRFORCE1, theres actually a thread floating about with somebody asking about a mk3 ibiza servicing and i thought it was maybe you, alot of people will recommend him as you wont get many across the country with his quality of work and pricing
Nope, not me!
Appreciate the heads up. Might get in contact to see about a service and brake pad change.
Spot on, thanks mate.
They quoted me a lot more than autotune did for a similar set up. I've heard some great reviews about them too!
Just wondering if anyone has any further info on VAG Servicing. My Toledo is due timing belt and water pump. I am in north down but work in lisburn area.
