NinjaFlavour
I'm talking about the single, usually phillips head bolt that holds the brake disc on to the hub once you've removed the wheel. (see part #1 on the image below)
The original one seems to be made out of cheese and so once I've drilled the currently stripped one out, I would like to replace it.
I've had a look and can't find any size specifications for the bolt to fit in there. What is it? I can only guess an M6 countersunk something?
Any suggestions on where to get some from?
