Hi guys, initial thoughts were maf which was replaced, lambda readouts look within limits? the boost actual and specified is what throws me off
car is a pre facelift mk1 cupra with the auq 180 engine
spec is :
silicone tip (new)
stage 1 map
decat and 3inch dp
full exhaust system
710n d.v (good condition)
n75e (new)
pipercross induction kit (new)
ko3s turbo
new genuine maf
as far as i know,no boost leaks present
boost spikes to 20psi and holds boost if in e.g. 6th gear under load
otherwise it will spike to 20 then tail off and hold around 9 as the revs climb
has a code on engine block for 17704 error in mapped coolant system which i have a fresh thermostat + CTS sat here waiting to go in (unrelated??)
i have the money to get this sorted but would rather avoid the stealers and get a more confirmed diagnosis.
here are logs
https://docs.google.com/spreadsheet/pub?key=0AuF2Qzt9PQgUdDlqMFZNbnBYc3JERmJEVUZUZTBEZkE&output=html
thanks for your time
any help would be greatly appreciated
https://docs.google.com/spreadsheet/pub?key=0AuF2Qzt9PQgUdDlqMFZNbnBYc3JERmJEVUZUZTBEZkE&output=ods
spec is :
silicone tip (new)
stage 1 map
decat and 3inch dp
full exhaust system
n75e (new)
ko3s turbo
new genuine maf
here are logs
