Mar 3, 2012
1,762
southampton, UK
Have seen people wrap the long strip of plastic on their from doors and I was wondering if this comes off from the door or you wrap with it in place?
Sent from my HTC One using Tapatalk 2
I found it was easiest to start by removing the end nearest the speaker first, then work your way along
Agreed. Make sure you use a decent tool or knife as said as they bend easily and leave a horrible white line in the bend.
Is this the same process for speaker rings?
What spray do you use
Just finished wrapping the trim. Was extremely easy to remove it in the end. Also tested how easy to remove the speaker surround was lol. Need more vinyl lol. Thanks all for your advise :)
Lol ok I no the rules
That looks spot on mate
Were the speaker surround easy and does the trim just click back in?
Removed the back ones can't get front ones off.
Hole is very small, what tool is best to use
Tried doing speaker surrounds and failed
Any tips??
There's a small bit closest to the floor of the speakersurround I used a butter knife to pop it out was insanely easy. Just look for the groove
Ye seen it but thought would ask first
Do they have clips all way round like trim?
Cheers fella got them off :)
I thought just the black ring would come out but it's the mesh looking thing also, will be tricky to wrap?
Nah be easy just place the wrap over the whole thing then use a scalpel to cut out the mesh. Will be doing mine next month. pics when your done mate
