APR Flapper delete mk2 Leon Cupra
frankmabo
I own a 2009 Seat Leon Cupra it comes with the same engine as the TTs, S3, Scirroco R or the Golf R, I´ve been using the apr software around 6 months with step by step upgrades, downpipe, intercooler, fuel pump, etc. I cleaned the catalyst from the mid pipe and added a resonator, modified AEM intake, bsh 2.5¨ throttle pipe and a custom 2.5¨ discharge pipe with the turbo silencer removed. I thought I had managed to do a clean full air cycle on my car.
I always heard the k04 flutter but when I installed the gauges I saw the needle bouncing and was sure something was not letting this engine breathe the way it was meant to.
While searching I saw Integrated Engineering´s intake manifold flange, but never got to see the point in that TBH, then APR came with the flapper delete kit, a simple cheap way to make your car breathe better. There are some cheap knock offs there is even a guy that wants to use my old flappers to try to seal them and use them on his skoda, but come on, it´s a part that goes almost INSIDE the engine, knock offs? plastic sealed?. geez
I wanted to test if the car actually made any gains from this so I fill the tank with the best (88-89aki) fuel we have in this country, put two gallons of xylene (115.5aki) to see if it raises at least to 91. The next day did some logging (there was much less timing pull than usual) so the xylene had an apparent effect and went to the dyno.
Preflapper dyno graph. Outside temperature 30.5c and a small portable fan to the intercooler.
After I got the car to my house and started the process of removing the manifold, is very time consuming and even with the right tools it´s a little difficult, professional asistance is definetly
recomended for most people. Keep in mind that the blue injector rings might come off, clean them and put them on the injectors before placing the manifold back. I´ve read a lot of people
saying that the injectors sometimes come out when you remove the manifold, that did not happen to me.
Since my car is only 20k km (around 12k miles) the valves where not THAT dirty, they had some gunk but not like the ones in the pictures of a few of the really bad cases. I used a full can of carb cleaner and a toothbrush (regular plastic one) and removed most of the dirt, There was one valve that I cleaned less because it was open and I didn´t want carbon to fall into the cylinder head, I placed a small ball of newspaper on each and with the toothbrush removed the outside of the dirt.
After removing the oem flappers I removed the clip that holds the arm and replace it with the supplied aluminum arm insert and placed the clip back in it´s place to hold it, carefully put the flapper delete pieces on the manifold and they fit around half way with mild pushing from my fingers, I tapped them gently with a very small hammer I have untill they where align with the manifold, put the rubber joint and started the process of putting back the manifold. Always remember to oil the rubber joints (throttle and mani) before assembeling back.
The first startup was kind scary, I had the car sitting for 3 days and I was not sure if I had to put oil on the valves (I did not), I wait it for the gas to fill a little, cranked the car 2 seconds and stopped I had to do this like 4 or 5 times before the car turned on, I warmed the car went to my apr friend and flashed the RFD program.
Flapperless run. Outside temperature 31.5c and the small portable fan was not working, keep in mind that this is a non air conditionined dyno just 3 walls and a roof but it´s the most accurate and the most constant here.
I knew that my max psi might drop a little because the engine eats up the airflow more, and TBH the flutter seems less and shorter, the engine sounds a lot less in idle, its a little more present when accelerating but smoother. It´s always nice to have 15+whp permanent on your engine.
I have some interesting ideas I might give a try, and if they work I´ll do a little review if I can get some free time.
feel free to ask any questions and if I have the answer I´ll be happy to give them.
Frank.
frankmabo
it´s the roughly equal of running a k04 100oct race file permanently.
Over 15whp from a single mod, if you can do the labor yourself or get it cheap there is no other better mod for the price.
at least for k04 owners like myself.
can someone name a cheaper mod that delivers over 15whp on our vehicles? that´s taking out the fact of a tad better spool up, and more hp across the entire power band.
Al
7,199
9
Mike - you gonna be changing your code if you add wmi? Last time I asked Evan APR weren't that keen on it and never had a file for it - although no doubt that may be old news.
frankmabo
UPDATE:
1. You can remove the Flapper motor and not get a check engine light or any other error codes that hurt our cars resale values.
2. The Air to fuel ratio in the first dyno run looks bad because the probe was not propertly attached to the muffler tip and fell.
3. The complete work can be done in one day, but it might take more if you have to do aditional work, deep clean the valves and replace the injectors.
4. This mod is a MUST if you are doing an APR k04 upgrade with S3 injectors, since you are removing your manifold anyways, DO IT.
Evan@APR
Thank you for the review.
However I wouldn't go as far as to say it's a replacement for race gas! The RFD kit allows for better air flow and that's all anybody should expect. It's great to see the gains you've experienced so far, but with the mixture in fuel you're using, one could attribute your power gains to inconsistent fuel between runs... and we know it's ALLLLL abou the fuel :).
Also, make sure you get your software updated to the RFD file to eliminate any rough running.
willc
93
I would be slightly concerned about how lean the fuel mix is, you want to be in the 11.5-12:1 area when running in boost! I bet you can't put much ignition in as it will knock quite quickly I'd imagine. Get the fuel mixture enriched.
frankmabo
I mean that a 100 oct file is around 16- 18 whp on the k04 tune and at least in my case the 15+whp (might have been more if the temperature had been the same and the fan had been working that day) is a similar kind of performance gain but I will have it as long as I have the car. I can always get some race gas and run the 100 oct file of more performance on top of that of the flapper delete gains.
I think the fuel was a little constant here,
I went to the gas station had two gallons of xylene and then fill up the tank Sunday morning (full till the pump stopped), I used the car a few hours and went to the beach (1 hr trip), then on Monday I used the car the whole day and around 10pm did the log, Tuesday morning I did the pre-flapper dyno run (had less than half a tank) and the post-flapper run 3 days later on the same remaining gas without putting anything there to make sure that the fuel (as good or as bad it is) was as constant as possible.
As for the air to fuel ratio, I think apr´s golf r, s3 and cupras run pretty close to 13, evan could shed some light a lot better than I on whether this is accurate or not.
frankmabo
I had the car flashed and then flashed again today with yesterday´s update, I talked to arin about an error I got in my car because I took the flapper motor completely off and he made sure APR had an update within 48hrs. That´s what I call PERFECT costumer service!!
POPOV
Newbie
Jun 25, 2005
581
Sweden
Nice review frankmabo, i'm a fan of APR myself. But i did get confused as APR's webpage lists a 10hp gain on a stage 3 car with the flapper delete. In your case you are stating a 15whp increase, or is that including the gains of the better fuel.
Any other dyno's avialble on this mod a stage 2+ APR car out there?
If i get 10 hp out of it on a stage 2+ car it is worth it in my opinion. Add VMI and run the APR race file, that should give you above 400hp and full front wheel control =) .
frankmabo
They where back to back dyno runs, the gains where just from the flapper delete mod, but then again I have a full air cycle upgrade in my car and the flapper delete was the last part.
keep in mind that I got over 15whp because the conditions where worst in the second dyno run than in the first and there is a loss of 12-15 % from the engine to the wheels.
I would say that if you have stock intake, exhaust, discharge pipe and throttle pipe, then the gains will surely not be as good.
cupra_ahhh
1,184
10
Tonbridge, Kent
Just to quickly mention fuel, what seems to be the best at the pump? I've only really ever felt a slight difference with Shell Optimax, but have been using BP Ultimate Unleaded for about 6 months now as it's the closer garage. Any others that you guys would recommend?
AndrewJB
Aug 16, 2007
11,163
483
Maranello
My APR Tune is for 98RON+
I use mainly Tesco Momentum 99 (99RON) or Shell V-Power (99RON)
V-Power has just been renamed V-Power Nitro+ now its believed its still 99RON though
Hurdy
Yorkshire - born and bred
Oct 7, 2008
709
7
South Yorkshire
Did the flapper delete mod on my Golf R just over a week ago. Great little mod and although it sounds a little hoarser I'm not sure how much extra power it gave me. Anything is a bonus[B)]
anthony37
Take No ****!
Jun 21, 2010
310
Edinburgh
I recommend when chosen this upgrade (Runner Flap Delete) you better of Porting & Polishing your TFSI heads to gain the best performance from this upgrade! You can also delete the Partition Flaps with in the heads.
The main problems on these motors are the carbon buildup as a result of its direct injection system and this will be another good way to rid of by deleting all of the circulating valves by replacing it with Subaru catch Can. I also would recommend to only do this upgrade if you are a BT freak.:)
Evan@APR
That's what you recommend is it? ;)
