LCR Brembo Bolts Loose ?
Sep 18, 2009
2,443
Shropshire
When I installed my LCR Brembos, I cleaned the thread on the hub and used new bolts for the caliper carrier. Problem ive got is I think the bolts keep coming loose giving me bad vibration under braking similar effect of warped discs.
Should I use some Loctite or something similar on the bolts to keep them in place better like a rusty bolt would.
http://www.halfords.com/webapp/wcs/...uctId_199363_langId_-1_categoryId_255230#tab3
Anyone know the procedure when installing new carrier bolts ?
vroomtshh
4,222
Dreghorn, Scotland
Do they come with the paint when you replace them?
I know they definitely need threadlock coz I've fitted them without before and the bolts eventually come loose
kinder
140
I've got the judder under braking as well but new discs fitted a few months ago been juddering ever since
Sep 18, 2009
2,443
Shropshire
tighten all the bolts up with threadlock and still judder under braking
there was me thinking te EBC ultimax discs and DS-2500 would be a good setup. looks like ive just pissed £300 down the toilet :censored:
vroomtshh
4,222
Dreghorn, Scotland
Are you sure its juddering and its not just the slots in the pads you can feel? They do kind of throb a bit.
Did you make sure the pad sliders had no corrosion under them and the pads are free to move? I tend to file about 1mm off DS2500s so they're loose in the sliders. Gives them a bit of wiggle room when everything is hot
Make sure the hub was perfectly clean before fitting the discs?
alias
317
Essex
When I did my fronts two years ago I just did the bolts up FT, and when I changed the discs and pads this last weekend gone they were still FT! Mine did have the blue on them from when they were first installed so threadlock probably isn't a bad idea.
