Hi Guys
I'm trying to sort out some of the rattles :D
Got the radio out, removed the two screws hidden behind the radio.
This thread suggests the panel just pulls out: I unclipped it all the way around the outside OK, but it still seemed attached very firmly just under the centre of the two vents, so I put it back to have another go another day. Am I missing anything?
That's it if I remember mate, you've just got to be brave and pull
Did you notice that there is 3 skrews you actually have to remove.
I did not have any problems about the removal. Just pull it off it´ll come.
3?
I only found the two visible in this photo, immediately below the climate panel:
Is there another?
Ahh sorry about that, my bad. I misready the previous thread that indicated that there would be 3 skrews.
But still. Im not too sure but there should be some skrews right under the radio after you pull it off and 2 skrews on the top side visible as you can see from the picture.
Pull radio out find 2 underneath climate control, on top of radio, pulled mine out last week
so that's 4 screws the two in your picture and another 2 underneath the climate control
