dalien2k
Hello everyone! Since I do not know English very well and could not find a forum on the topic that :( So please tell, maybe someone knows how to completely off ESP system? I just need to ABS. The car is used for amateur racing circuit, and ESP is impeding active driving.
OK, what do you bring "hazards on" ?
It works :) But as soon as I start to go off (ABS is also turned off. There are other options?
Find the fuse for the ESP system and take it out? (assuming that fuse doesn't also fuse lots of other useful stuff, I haven't got ESP so I can't check)
If you pull the fuse, the disabled and the ABS. I've tried it, the machine becomes unmanageable when braking. When my friend on the Fabia RS demolished concrete bump on the track without ABS.
Yeah, ESP works with the ABS sensors if I'm correct.
I think if you really want it off, you need to take a look with VCDS I think.
It can't be fully turned off as it's linked to the ABS, so no ESP = no ABS, which will throw the brake bias off as well.
Pretty sure there's no option in VCDS for it to be disabled.
Turn off the ESP and ABS may leave, it is implemented in the Trophy, but you programirovat control unit. I believe this is the only way out.
Has anyone got any further with this?
I've been unable to disable the ESP as yet, having tried with Vagcom:
To recode the ABS controller long coding for 2 stage ESP off as with 2012+ golfs/leons/octavias
To disable the steering angle sensor on the ABS controller Adjustments (channel 9) as with earlier golfs/leons/octavias
There must be some coding out there that can do this...?
Hello,
I'm French and speech not good english, so sorry for my english !
This manipulation don't work on my Ibiza Cupra 2011.
When I put ignition on, hazards on, pump accelerator pedal 5 times rapidly, start engine, The ABS and ESP lights are turned On, so everything is ok.
But when I started rolling, they will be Off and the ABS and the ESP work...
Did I miss a step ? Has anyone a solution to disconnect the ESP ?
I'm still trying to find a solution that would use the ESP button to turn it off.
I did try variations of the coding found on Golfs MY8.5-11 recently, plus the latest Mk7 Golf programming, but none of that seems to work.
Probably the easiest way is to disconnect the steering angle sensor though I haven't tried it.
It will probably throw up a fault code if this is done and it may also need recalibrated.
