Mt turbo blew up 3 weeks agao (BKD 2.0 TDI) so I replaced it with a reconditioned unit (new "cartridge" ) supposedly fully balanced.
It all went on Ok with new oil feed pipe, gaskets for oil return and exhaust manifold. Oil feed was checked both before fitting turbo AND after fitting oil return pipe to turbo, but not to engine block. At all flowed very nicely (Old turbo did not fail due to oil feed anyway as it dumped most of sump into the inlet and exhaust)
All of the inlet piping was removed and cleaned with degreaser then steam cleaned, including intercooler.
Car goes ok but following symptoms:
1. After about first 50 miles there was a definite turbo spin related "chattering" that lasted for about 5-10 mins. Not heard it since.
2. Turbo definitely has a delay in "spinning up". There certainly isn't the urgency of power delivery that I had previously.
3. The turbo is quite noisy when it does spin up. My original one always had the owl hoot/police siren sound but made no other sound. The recon has quite a loud sound which I can best describe as like a plastic bag fluttering in a strong wind very noticable at any throttle position other than cruising on level. Any hill and the sound is there or more than gentle acceleration.
4. Just done 2000 mile round trip to France mainly motorway. First day /450 miles no problems but second day and worsening from then on the ecu flips into limp mode after about an hours driving, usually on partial load, at speed, say accelerating to overtake lorry. Repeatedly does it after switch off reset. Doesn't do it on 3/4 to full throttle acceleration and far less so when in Sport mode of DSG.
Have checked several times with VCDS and each time showing Boost regulation error.
Have I got a duff turbo? Thinking either the variable vane setting is wrong or faulty. The actuator rod works, Ive checked it with VCDS and it moves just fine
Fault code: 16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2226 /min
Torque: 230.0 Nm
Speed: 109.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 01101000
Absolute Pres.: 2070.6 mbar
Absolute Pres.: 1642.2 mbar
Freeze Frame:
RPM: 2226 /min
Torque: 230.0 Nm
Speed: 109.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 01101000
