I bought a Seat Ibiza Cupra at the weekend and here is the spec that came with it and a few of the seller's photos:
Fully Rebuilt AYP Engine.
Intergrated Enginering Rifle Drilled Forged Conrods.
JBS High Flow Exhaust Manifold.
KO3S Hybrid Turbo.
Pro Alloy Intercooler Kit With Custom Bam Style Pipe Work.
Blue Flame Exhaust System.
Forge Tip.
Forge Silicone Hoses.
Forge 007 Recert Valve.
Jetex Air Filter.
N249 Bypass.
VW Golf MK4 Turbo G60 Flywheel & VR6 Clutch.
Secondry Air Injection Removed.
TT Injectors & AFM.
Milltec Down Pipe.
Custom JBS Remap - 269BHP / 285LBs.
AP Coilovers front & Rear.
Fully Polly Bushed Through Out.
OMP front Top & Bottom Strut Braces.
OMP Rear Strut Brace.
Vibra-Technics Engine Mounts.
Tarox-6 Pot Front Brake Set-Up.
20mm Spacers All Round.
Standard Half Leather Cupra Interior.
Nomad Single Pillar Pod trim With Digital Boost Gauge.
Cupra R Center Console Gauge Pod With Water & Oil Temperature Gauges.
Roof Lining & A,B,C Pillar Trims All Painted Black, Audi Style.
Standard Cupra Body Kit.
Seat Leon Cupra R Front Splitter.
HID Head Lights.
I traveled a 12 hour round trip down to Essex in the miserable rain at the weekend to pick up a car I've wanted since I drove a Quiksilver, a good few years ago. She wasn't perfect but I knew this was the car for me.
The weather has been all doom and gloom so I thought I would work on the Interior until the weather gets better!
So, first off! It has a tape player...
I bought a Cassete > Aux lead from Argos but it was terrible, knocking around in the tape deck and making cringe-worthy noises. There was only one thing for it...
The handle surrounds have seen better days...
I saw a guide on here on how to remove them, so I decided to pop to Halfrauds for some supplies to smarten them up. That's tonight's job!
The rear windscreen wiper made a horrible noise when it went, so while I was in halfords I bought some new wipers. Bosch Aero Wipers all-round and they work a treat!
The upholstery looks like it could do with a bit of a scrub up and while I'm at it I may as well treat the leather, so again while in Halfords...
I'm going to remove the snail vinyl on the back, maybe get something else but in the meantime, i have these to stick somewhere...
Other plans on the cards are to:
- Bleed the clutch because it needs pumping a few times to go into 1st gear.
- Clean up the engine bay with degreaser and metal polish.
- Change the Driver's side front because it's starting to get a bit low on the tread.
- Do something with the exhaust, because at the minute it's just a loud drone. I would like something with a little more tone, if anybody can share some insight on exhausts?
KO3S Hybrid Turbo.
Forge Tip.
Jetex Air Filter.
N249 Bypass.
TT Injectors & AFM.
Milltec Down Pipe.
HID Head Lights.
