benbissett
109
wick , caithness, scotland
my leon fr tdi 150 has a problem ... when im driving the rear is crabbing behind .. ive had a quick look under and it looks okay ... any ideas ? oh nd both back tyres were bald on the inside ?? this I don't get ?? cheers in advance
Have you had the car a while ............... could have been in an accident and bent rear torsion beam axle.
Check the axle mounting hanger bolts are tight .
Most likely cause is a siezed rear brake caliper . The faster you go the more heat that is generated from rubbing pad and the more it siezes on causing the crab and tire wear .
