update on this well the wire queen suggested from xbox360 just does not work!!
it installs the latest software great...
you click on test run and it says it needs to update the HEX so you click update and it just keeps saying FAILED!!!
tried for ages... unless I am doing somthing wrong lol...
ffs
says this
The Firmware in your HEX interface is out of date!
Current HEX Firmware Version: 1.92
This version of VCDS requires: 1.93
Click the UPDATE button to update your HEX interface.
*The interface MUST remain plugged into the car
* An Internet connection is NOT required.
but wont let me update
ffs
says this
However you can email the Chinese and maybe they can sort it out for you.
12.12.3 uses fw 1.92 so it's obvious you downloaded or installed 14.10.0 which fw 1.93 chinese hardware's 12.12.3 have blacklist serial or and has very low quality chipset either NEC or CHINA
You can try installing 12.12.3 on VM with no internet try it again
as Dan FR said you have 1 dead interface
BTW ! can you open it post a pic ?
Far easier to buy a new one for £11. They will only turn around and tell you it's your own fault, which it is
Putting aside all the legal and moral reasons why you should not buy rip-off copies, if you buy the proper VCDS from an authorised seller - and there are many in UK, you will get supported for the lifetime of that product, and when the time comes for RossTech to replace it with an evolved tool, your old version can be traded in. You sound like, so far, you don't have a great car issues and just want to enjoy the benefits of being able to change things slightly in your car, and that is fair enough, but unfortunately, in the future, you will probably want to be able to find out what is going wrong with your car, and either try to fix it or make a judgement on if it is safe to continue to use it. This is where these scan tools come into their own and your £270+ spend will pale into insignificance.
If you plan to work your way through/up the VAG range of cars, getting a proper copy of VCDS will keep working for a very long time, I've had VAG COM since 2002, then traded it in for VCDS, so my total spend of maybe £185 + maybe £155 to upgrade, has kept me up to date for 12 years and going looking after/fixing 5 cars and some friends cars - remember, VCDS can operate as an OBD2 generic engine code reader for any other marques that are playing the game wrt OBD2 code designations!
One last thing, the power that this tool gives me to talk to my cars, kind of keeps me owning VAG cars, because after having this, I would feel lost if I could not check the car faults - duff garage man says "blah blah £1000 mate!" now how can you argue against that when you have nothing to back it up?
Yes all chinese version will have update reminder mate stop this need to turn pc time backyep I tired and kept getting this...
then the 14 this but wont update... this was the only option that kinda worked but not fully as you can see..
if you install 12.12.3 connect to the car start software then select [options] > [test] interface
take a screen shot if give's error of any sort you may throw it in the bin
