Cupra 290 lowering
LiamCupra290
67
Few questions about lowering my new 290 Cupra!
I'm ideally wanting to use Eibach, anyone know if there are sport line springs from Eibach designed for the current Cupra?
Anyone already got a 280/290 lowered? What are your experiences with the ride/handling etc.
And finally is the DCC affected? I like the DCC not sure whether lowering it would be worth sacrificing...
Thanks all!
LiamCupra290
67
All the usual suspects offer lowering springs / coilovers for the car.
I run VWR springs (made by Eibach)
How have you found the VWR springs? Initially my preference was the Eibach Sportlines for the increased drop but I've read a great deal of good press on the VWR springs...
Would you say the VWR springs offer a noticeable drop? I'm after filling the wheel arch a little as I think the standard height is slightly too high for the gap.
LiamCupra290
67
I'm looking to go with one of H&R, Eibach or VWR. Anyone with any experience with them? I'm curious to know what the drop is like on each because people seem to suggest Eibach for a greater drop than the VWR but according to the Eibach specs they drop 20-25mm, the exact same as the VWR?
SteJP
123
VMR don't drop really anything so I decided not to follow the crowd and go for H&R Springs with a 35mm drop. Make the car look so much better. Handles good and they support DCC. Noticeable difference between Cupra and comfort
Xpo
96
18
Sweden
I put h&r springs on my 280 with dcc and they ride like stock. Lowered an additional 2.5-3cm front and back.
DamianPM
6,387
83
Newcastle/Durham
Thanks all!
Eibach list the Pro springs for the Cupra model - https://www.dpmperformance.co.uk/ca...g-suspension-springsleon-5f-cupra-20t-si-0912
Damian @ DPM Performance
Bahnstormer
Cupra 280 DSG
May 16, 2016
25
Will the tyres rub the fenders with a 35mm (H&R) drop? I usually drive alone or with the missus but in the summer time the car can be fully packed and with 3 person on board.
30-35mm seems like a lot but I'm still temped to get those if the comfort isn't too compromised.
Btw, I have 19" stock wheels and tyres.
LiamCupra290
67
I've decided to go with the H&R 35mm ones though the email H&R sent me suggests it will more likely be 30mm front and back. Can't imagine it will be a problem, I've seen ones much lower!
Xpo
96
18
Sweden
Yes it's around 25-30mm drop. I have 18x8" et45 with 225/40 tires and no rub whatsoever. With stock wheels(i'm guessing you're on 19x8" et50 with 235/35) should be no problem at all.
