Presuming all tyres have always been on the same corner, due to the camber settings on FWD cars the insides of the rears fitted with wider tyre fitments normally wear on the insides before the outside, so this is odd. Front wear as described indicates the car needs to go on geometry machine if 13K miles on front tyes bothers you (wish I could get that) but as the rears have worn on the outside then best you do have a 4 wheel alignment check. Both your front wheels are slightly toeing inwards, in both case are corning fast.
Either way good luck luck with finding any company to successfully get the set up correct and running straight if your fussy like me..
