Hi all I'm looking to buy a uprated performance clutch, I've found one from Sachs in Germany for around £600 and £70 for uprated bearings.
The problem I've got is that it fits the ST and I couldn't see why it wouldn't fit the SC or 5 door for that reason, obviously the wheel base is different so the drive train would be slightly different but the mechanics of it should be identical.
If not I'm thinking of going down the MK7 Golf GTI fly wheel as it's a higher spec and 13mm thick instead of the cupras 11mm thick flywheel and getting a heylex clutch system installed
