To quote Eibach..
Sent from my Pixel XL using Tapatalk
But they also say the 35/30 drop is for the SE, and FR is already 15mm lower than standard
To quote Eibach..
There are spring kits listed " for models with sports suspension" and thus it gives the required drop as mine did.But they also say the 35/30 drop is for the SE, and FR is already 15mm lower than standard![]()
I have no point to further convince you.. This is what Eibach said when I contacted them.There are spring kits listed " for models with sports suspension" and thus it gives the required drop as mine did.
Quote "I seriously doubt it will ride any better on eibach springs than standard, because you havnt changed the actual dampers"
To quote Eibach..
"The Eibach Pro-Kit is the perfect answer for most popular street cars.
It’s our legendary spring system that dramatically improves both a vehicle’s performance and appearance. Pro-Kit lowers your car’s centre of gravity, reducing squat during acceleration, body roll in corners and excessive nosedive under braking."
Did I get that wrong as well ??
Well done. top marks for reading the side of a box.
Do you believe everything that people write on the packaging to help them sell the products then?
By the way what engine is in your FR?
It's off Eibach' website. 1.8tsi. DTUK box , Forge carbon MQB intake kit and revo turbo muffler delete.
I just don't get why you have to be so negative.
To make the best of these mods you should probably consider a bespoke remap as the intake and exhaust wont be doing too much (other than noise) with the DTUK box as it only alters fuelling/boost/ignition based on a pre determined map which was written for standard cars. Personally I'm not convinced that the intakes do anything at all other than increase noise, but a remap might prove me wrong.
Was that positive enough for you?
To be fair, I was just giving an opinion on your post about wheels and on the pictures you posted about the drop of the springs you've fitted, that is the point of a forum - discussion.
What sealer did you use ?
Glad to hear it..I've just done mine with the same stuff. Wasnt sure what else to buy but the reviews were good. First time using it and seems easy enough to use.
How long does it last usually until you have to recoat?
How many coats do you give at a time ?
