Ibiza Good Stuff. iPhone Cable
Aaz
May 21, 2011
512
Kent, England
Anyone have link to the cable required to be able to plug in and play music from an iPhone 6 using the cars USB slot?
Thanks.
j.owen
413
St. Helens
Correct me if this answer is too obvious but won't a normal iPhone charger work? That's what I use to utilise CarPlay etc
Aaz
May 21, 2011
512
Kent, England
I did try that, but nothing came up on either screen all it did was charge. Is there a setting in the iPhone i have to select?
j.owen
413
St. Helens
Does your car have CarPlay functionality? I'm assuming it does if it has a USB port, if so just unlock your iPhone and it should work.
If it doesn't have CarPlay then I don't think you can listen to music via USB, you'd have to use aux
propane94
Bearded Ginger
Nov 15, 2012
406
12
Portsmouth
SwinDan
71
Swindon
As above only works if you have a system with full link if you don't then you can use Bluetooth or a memory stick
