I will do once I’m back from holiday I looked into this myself briefly on the xcellence there are bolt heads in the circular recess just behind the back of the front seats, you may have to slide them forwards. It looks as if you may remove the small tray at the rear of the whole centre console and then just sit it on top and secure with any supplied fittings/bolts.
Did your dealer say they could get the part?
In which case coding will be similar to this:
Select STG 09 (vehicle power)
STG access authorization -> Function 16
Enter unlock code 31347
STG adjustment -> function 10
(22) Access control two radio Select Spiegelanklappung mode
Adjust Value accordingly as desired
default value: by convenience surgery via remote control key = FFB must be pressed long to allow Fold in the exterior mirrors
Alternative: by look command via remote control key = FFB must be pressed briefly to let the outside mirrors Fold in
VCDS received. Latest version. 17.8.0
Plugged into car excited to make changes.
“Unsupported Vehicle”
It’s a proper Ross tech cable not a Chinese knock off.
I guess I have to wait for it to be updated
Honestly, I just forgot about it - apart from ordering a few bits off ebay.
Went back to my day to day life, driving the old car and then one day the phone rang " Your car's arriving tomorrow, when can you collect it later in the week?"
Nothing you do is going to get your car any faster.
In fact, nagging your dealer will possibly p155 them off and reduce the level of service or urgency.
I think you're probably right on the last point! My policy is to leave it, but I just wasn't sure how much communication to expect and when to expect it.
