Leon Mk1 & Golf Mk4 door seal/trim - identical?
6th.replicant
698
9
London
So, you know the rubber trim/seal that clips onto the whole length of front edge of the rear doors, and then in turn forms a seal when the front door closes? Anyone know if it’s the same on a Leon Mk1 and a Golf Mk4?
Ta :)
maccyb
I need to replace these very things... but I can't find a part number or a name by which to find them. Anyone know if & where they can be obtained?
maccyb
Awesome, thanks for the quick response. Now to see if anyone has them available...
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,257
1,110
Kent
Which ones do you need exactly as I've got a few spares from a FR TDI I'm breaking.
Sent from my SM-G930F using Tapatalk
maccyb
As the OP describes - the outer door seal strip that goes down the front edge of the rear door and seals against the front door - needed on both sides. Current ones have perished/degraded to the point where they won't stay in position.
I've got an 05 plate Mk1 (1.8T) if that makes any difference...
maccyb
I also have the apparently common issue with the lock on the rear nearside door no longer working... I've seen the instructions on replacing it and am debating whether to get a proper mechanic to do it!
verbal_kint
639
31
North West Kent
It is not that hard if you are a moderate diyer. Follow the guide and you won't go far wrong. Just did mine last week and when the door accidently closed before I had set it all back up it just told me I was wise to not let it get to the point where it failed completely.
OOO...when you say no longer working I hope you can open it?
maccyb
I can open (and close) the door, it won't lock at all. Are you referring to the guide on vwvortex.com that ends in 1015107? (I can't post links yet)
Guess I'll need a locking unit and the 8mm triple square tool...
