Oct 28, 2017
25
VCDS disable Start / Stop
1.select 09-Cent. Elect.
2.select 16-Security Access (code 20113)
3.select 10-Adaptation
4.Channel 34
5. enter new value -Add32 to storing status on/off
-Subtract 4 from value to be disabled on ignition every single time
34=4 (4-4) 0 disables it every single time.
Hope it helps.
Sourced from different Forum.
Hope it helps.:rofl:
I don't know what "channel 34" is. It isn't in the adaptation section...
Your right. It seems this option isn't available on MBQ platform. However, it works only on older cars...:hole:
Option 2 is :
Module 19(CAN Gateway)
10-Adaptation
find in the drop menu: Start_Stop_voltage_limit
the default is around 7.6V, change it to about 12.1V and it won't interfere again
or just disable at longer coding helper.
I've adjusted my motorway light speed at the 09-central electric module from 140km/h to 100km/h in the long menu at the same time, so it wasn't a complete waste of effort.
