Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I had a 14 plate TDI FR - lost all heat etc - took it to the dealers for inspection and they had to replace the full heater matrix (dash out job) they had the car for nearly 2 weeks!! was given a crappy 107 to really rub it in.
Hi Scott,
Was wondering if you ever posted an update on how to replace the heater matrix start to finish (couldn't find another post?).
I've just found out that the reason for no hot air through my vents is a faulty heater matrix. Garage have quoted me £800 to fix. I've got a few days off and was thinking of replacing it myself, depending on how difficult a job it is.
Thanks,
C
Thanks.
Where/how do you disconnect the hoses from the firewall?
Thanks for all the info Scott, what seemed to be a impossible task is actually now inviting.
I do however have a couple of questions.
1. I managed to get to one of the bottom connectors on the radiator to drain the coolant, this was a sh$tty job to note! Unfortunately I only managed to drain about 2 litres of coolant, I switched on the car briefly to see if the water pump will get some more out but had no luck. How do I completely drain the system?
2. Am I correct in saying the system self bleeds?
3. Got in under the dashboard as per your instruction and got to the matrix, don’t have a replacement yet but just wanted to give it a test run. My problem however is removing the two pipes in the engine bay that goes through the fire wall, do I just yank them out? Couldn’t see any clips?
4. The is a electrical sensor just in front of the heater matrix. How do you get this out? It has a little red tab that you pull back but after that this things still sticks like sh£t to a blanket?
My aim is to replace the matrix this coming weekend. I have tried to flush the system, the reservoir is full of gunk which tells me the garage who’s done the last service did something wrong.
Anyway thanks once again for shedding some light on this task.
One question is does anyone know why I would have the jelly substance in there? Car has full service history with Seat and I had the car from new so the only people who ever worked in the coolant was the service centre. Can this be from using different grades perhaps?
