39F / 35R is in PSIThanks
How much is in lbs?
My new 300 came with 40 PSI front, 36 PSI rear
yup, check the passenger side door frame, it states the required tyre pressuresAnd u have 235/35/19 tores
225/40/R18I do own 2018 1.8 FR with 18" wheels and I'm quite confused why I have two settings for pressure in the label.
Any ideas?
I did look up in owners manual, but no info there. View attachment 145
Sent from my Pixel 2 using Tapatalk
The lower pressures are a 'comfort' setting.225/40/R18
InterestingThe lower pressures are a 'comfort' setting.
Interesting
I also found the esp to blink more often when on 2.7
