Hey! Question.... the resonator delete pipe for the Cupra 300. Can this be done as a straight swap without effecting the car in terms of, do I need to map the car with the res delete pipe fitted, will the pipe cause issues with fueling or performance if not mapped?
Not settling for a turbo back system or mapping at the moment and would like something a bit more from the Zorst note and these delete pipes sound great.
Advice welcome...
Advice welcome...
it should be okay come the end of the agreement? As if I wanted to keep it then it’s no
if indeed the baffles are being destroyed then if you put the res back on it may sound louder then original?
