So tonight on the way home from work I notice some clutch clip! A few weeks back I thought it was a boot leak or loss of power but a few youtube vids confirm that it's clutch slip.
Im doing 30mph in 3rd and changed to 4th, put my foot down and from 2.5rpm it goes up ok to 3rpm and then revs right up with no extra torque or pull.
Under normal driving it seems ok using the rpm range changing the gears at higher rpm. I've a Flywheel Dual Mass LUK 02M 6Spd Sachs Clutch
Then the remap! Very interesting.. I've been doing a little investigating the 2 print outs are of the same day but an hour difference.. Now the earlier map was done at 11:57 and the engine power is 264 BHP and the engine torque is 313.6 lbs of torque yet the later map was done at 12:57.. And record less bhp 237bhp?
So my question is Wtf is going on? I'm all questions but non of the maps make sense and the clutch should be able to hold its own shouldnt it?
Sent from my COL-L29 using Tapatalk
