Pricey_Jnr
18
Hello all, I'm trying to find out what springs I can fit to my Leon.
Are the FR spec cars lowered a bit from stock already?
I'm trying to figure out if any spring kits (35mm etc) will be the given calculations from a stock Leon height or a FR models height?
If anyone has done this to their 1.4 FR already, it'd be much appreciated if you could reply with how much you've lowered yours by, and pictures would help my decide a great deal.
Cheers!
Sent from my EML-L09 using Tapatalk
Hopefully someone can help you with your other questions. But calculations usually assume a stock height Leon. From my experience, the MK2 FRs were lowered slightly over a stock Leon, so I don't see why the MK3s wouldn't be.
I'm sure i read somewhere (maybe the configurator or in the spec sheet) that the FR is 15mm lower than a non-FR model
Found some specs online for your viewing pleasure.
Thanks for that mate, gives me a good idea of what I'll achieve. Did you fit them yourself?
I’m afraid not don’t have the facilities so used a local VAG specialist was about £250 including a full wheel alignment.
We generally find the FR model is around 15mm lower than a standard spec so a set of 35mm lowering would only give you a 20mm drop unless specifically for the FR model.
Damian @ DPM Performance
Thanks for that! Would you be able to link me to the lowest spring options available for my car, please mate?
Cheers!
Lowered on 35/30 Eibach springs.
