Never tried hand polishing a car, although I’ve read of others doing it with varying degrees of success. Hardness and general condition of the paintwork will be factors that influence the success of hand polishing.
It might work OK on light scratches or if scratches are localised in specific areas, provided you use an appropriate grade of polishing compound and foam applicator pads with a sufficient degree of ‘cut’. If you’re needing to hand polish the whole car, that sounds like a lot of time and effort, especially on hard paintwork. it takes me 2-3 days to polish my VW with hard paintwork using a dual action machine polisher.
If your paintwork is swirled, rather than scratched and you want a quick fix, you could use a filler polish that’ll mask the swirls. This would only be a temporary fix though, and the filler polish will need to be reapplied every couple of months (or more frequently if you use auto car washes or one of the many hand car wash places) to continue hiding the swirls.
i only have few spots, what filler product do u use?
Don't think you have to look any further than the well known Autoglym Super Resin Polish.
(But if you have some noticeably scratched areas I would give these a going over with comething like G3 compound first.)
@Tara; I also invested in a dual action (DA) machine polisher a few years ago and polish my cars myself. A DA polisher is quite a forgiving, safe machine for the amateur detailing enthusiast to use, with minimal risk of burning / striking through the clear coat. I’d be a bit more hesitant to use a rotary polishing machine though, which is probably better suited to the experienced, professional detailer. With good prep of the paintwork before polishing and the right combination of pad and polish, if you take your time it’s possible to achieve very good results with a DA. My polishing machine has more than paid for itself if I consider what I’d need to pay a professional detailer to polish my car.
Agree that it’s always best to start off with a mild cutting compound and medium or even a finishing pad. If that doesn’t achieve the required results, you can always step it up to a polishing compound that’s a bit more aggressive and a pad with a bit more ‘cut’.
I’ll be polishing my car at some point in the next few weeks; even with a careful, safe washing technique it’s got some light swirling that I want to remove. Once polished, it’ll be protected with a couple of coats of wax or sealant.
thanks I'll try the autoglym super resin polish
stupid question no.1
right now I'm using autoglym aquawax which I apply after washing while it's still wet, at what point I apply the polish?
1 guess: after washing and drying
but than I have to re-wet the car again for the aquawax?
Can super resin polish sorting the round wash scratches?seat messed the car everywhere.
I dont want to go back arguing...
