ryancboyo
14
Scarborough
Please can anybody help me locate the tap to drain all coolant. Or tell me how to drain all the coolant as I desperately need to do a coolant flush and refil.
I drive a 2006 seat Leon 2.0 FR tdi (mk2??)
me and my mate have been trying to do this for two hours today and the radiator pipes connected to the radiator have no tap for draining. One pipe is connected at the top, and the other is half way down. So I can’t drain by pulling lower pipe either
Nothing in the bottom of the radiator?
Maybe you just pull the lowest pipe off from the circuit and drain from there? Perhaps you can't 100% drain the system with it in the car?
Hi mate yeah there is no tap to drain from as iv found ok previous cars. And the lowest pipe from the radiator is half way up the radiator so really doesn’t drain much!
Whats happened to urgently nerd a full flush.....the only time i.ve flushed mine is when i change timing belt and do water pump at same time...ps don,t forget to only use the pinky red antifreeze only NOT blue as destructive to engine &seals
Sent from my SM-G935F using Tapatalk
Somebody has mixed blue and red in my coolant bottle ‍So need to flush asap! ♂️, and yeah mate I have purchased some red. Cheers
