Battery drain
Stewie14
50
Hello all
So I've recently upgraded my stereo to a rns315 and I'm suffering battery drain, after a bit of research I've found that it might be my canbus the number is 1k0 907 530 h, I've found one on eBay 7N0 907 530 AQ will this one be ok?
Regards
Stuart
TimSawf
865
South Manchester
The direct replacements up to Aug 2013 are shown as :
1K0 907 530K
1K0 907 530L
1K0 907 530Q
1K0 907 530S
1K0 907 530AD
7N0 907 530
7N0 907 530C
7N0 907 530H
Stewie14
50
1K0 907 530K
1K0 907 530L
1K0 907 530Q
1K0 907 530S
1K0 907 530AD
7N0 907 530
7N0 907 530C
7N0 907 530H
So will the one I've found be ok?
TimSawf
865
South Manchester
Can't answer that, AQ is not shown on my version of ETKA, may have been introduced after 2013 so can't confirm if it will be a suitable replacement. There are plenty of the others on E-Bay.
Stewie14
50
No probs I've ordered a 7N0 907 530 C
I'll just send the other back when it arrives
Thanks for your help
Brimfull
1,385
418
Wrexham
1K0 907 530K
1K0 907 530L
1K0 907 530Q
1K0 907 530S
1K0 907 530AD
7N0 907 530
7N0 907 530C
7N0 907 530H
Sorry to drag up an old post, but will all the above part numbers prevent the battery drain issue when retrofitting the rns510
Stewie14
50
As far as I’m aware these modules all stop the drain, try asking the original poster timsawf he might be able to advise better
Brimfull
1,385
418
Wrexham
Thanks, hes not been on line since August 2018, fingers crossed he gets alert from the thread
Brimfull
1,385
418
Wrexham
Failing that order the one I used
I take it the part you ordered stop the drain issue then? What year is your leon mine is 2006 on 56 plate.
I believe the module is located under the dash above the pedals
Stewie14
50
Mines a 06 56 plate, yeah to get to it you need to take the trim on the bottom of the windscreen off and a filter plate if I remember correctly, it’s a bit of a task, be careful you don’t damage your windscreen like I did
Brimfull
1,385
418
Wrexham
Cool thanks, I was surprised that the steering wheel controls all work well apart from the fast forward and rewind song buttons they do I was expecting none of the buttons to work with the older type canbus module
Brimfull
1,385
418
Wrexham
Fitted the replacement module this morning, not too bad of a job made easier as it appeared that both wiper arms had been removed recently so they came off without any bother.
Reactions: Stewie14
