SlashProm
160
22
Could do with a new set of springs all round for the LC 180 AUQ. Front has sagged a lot. Anyone got the part numbers for the Front and Rear OEM Springs as well as part numbers for front and back OEM Shocks please?
It just seems to show like 30 different ones that will do the job. Also says that the 1.9tdi springs are the same, does that mean these ones will fit?
https://www.ebay.co.uk/itm/For-Seat-Leon-1M1-1999-2006-2-Front-2-Rear-Coil-Springs-Set-Pair-x4-New/302875561726?_trkparms=aid=555018&algo=PL.SIM&ao=1&asc=57924&meid=f8f81b10d03a449196685336d9e42938&pid=100005&rk=1&rkt=12&sd=401502811743&itm=302875561726&_trksid=p2047675.c100005.m1851
It says they are compatible with the 1.8t audi a3 and 1.9tdi leon, any ideas? seems a bargain for the 4
Cross referenced with the oem page and they seem to match up
You will need the PR code to narrow down which springs are fitted to yours as standard. Codes are often in the handook or under the boot carpet. Often worn away by now though. May be worth putting your vin in if so and seeing if that narrows it down.
Just happened across some information from an old member on this site. I thought I would share it to help future generations.
All the springs are basically interchangeable, they will just have different heights and spring rates depending on year of manufacture and engine code, that sort of thing.
So some springs may say they fir the 1.9tdi but they could well be 20mm shorter ones that come on the cupra r as standard, so you could essentially get a stiffer 20mm lowering spring, OE, for the same price.
They seem to go from about 336mm height to about 362mm, I'll be going for the 362mm
