Lozzy15
Mods mods mods
589
409
Ilkeston, Derbyshire
Reactions: OJ9693 and cuprak04
@Lozzy15 great right up thank you,
@cuprak04 I have these as well and along with all my other mods have made a big difference to my handling.
Just a quick question I was under the impression that the bolts were one time use only.
Have a check of https://forums.seatcupra.net/index....k3-leon-do-today.379107/page-338#post-4862306 this also has the torque settings.
I've added the torque figure into the guide. In regards to them being stretch bolts i.e one time use bolts, they did look like stretch bolts. That being said I have reused stretch bolts in the past with no issues. I've seen other people reusing them over the years too without problems. But of course, as the name suggests, when they are first tightened they stretch and therefore, in theory, shouldn't be used again. It's upto you whether to take the risk of reusing or get some more. I would imagine new ones from TPS or the dealers wouldn't cost much. I have purchased new stretch bolts in the past for things like engine mounts and they were usually a couple of £'s each. Hope that helps.
Cheers for the guide , got mine in the same batch and fitted with help from your guide .
I find out If remove the corner clip on the scuttle tray it gives you even more room for ratchets without risk of damaging the tray.
Nice find, didn't even notice those were there!
