Leon ('65 plate) Cup Holder Rattle?!
Sep 16, 2019
Hi all!
Proud to upgrade from my older Ibiza to a 65 plate Leon FR (2.0 TDI DSG) today.
I absolutely LOVE the car so far, it's so much nicer to drive, more comfy in every way, it's just better.
However, when I placed a Coke bottle in the central cupholders, the rattle was ridiculous!
I presume the doorbins are going to frustrate me just as much with their rattles...
Anyone have a link to a product that can solve my woes, little rubber inserts for the cupholders or something similar?
Thanks,
Tom!
womble68
119
8
Bebington, Wirral
I've lined things in the past with black or dark grey sticky backed felt. You can usually find this in an arts and crafts shop or similar, just damps the noises from the plastic.
Sent from my SM-G975F using Tapatalk
Reactions: Tcshad
paddy6789
1,627
1,080
Preston, Lancs
The cup holders in the Leon's are by far the worst design ever... The preface lift ones were just about usable if you wanted a full size cup/can/bottle and a mini bottle - the facelift ones are even worse and so you have to choose whether you want the cup to rattle, or whether you want it to fall over.
Whoever was responsible for designing them needs to take a good, long, hard look at themselves in the mirror!!
Sep 16, 2019
I'm prefacelift, I believe, and it's just solid hard plastic that makes a lot of noise. In other cars I've owned they've had rubber inserts, but I've had no look finding any for this car
womble68
119
8
Bebington, Wirral
To be honest the prefacelift aren't that bad and I expect I may miss them myself as I could fit a pint sized glass in them. I dont expect the same in the facelift.
Don1961
212
118
Hi all!
Thanks,
Tom!
Hi @Tcshad I've just ordered this set, as recommended by someone/somewhere on here....
https://www.graficar.com.tr/product/seat-leon-5f-mk3-konfor-seti/
It has bits for cup holders, box under the centre armrest and all the door pockets. It's all pre cut and includes sides for cubby holes and door pockets, not just the bottom bits. Plus there's a couple of videos on the site showing how to fit it.
You'll need to select the year of your car (options go back to 2015) and also add that you require a set for a right hand drive car.
I'll let you know what it's like once I've fitted it
Hope this helps.
Sep 16, 2019
Hope this helps.
Hi Don, that's awesome, please let me know!
Sep 20, 2019
110
50
Totally agree.
I still haven't found a drink that fits in the smallest one!
Reactions: paddy6789
Don1961
212
118
It's finally arrived and so far so good.
I've done all the cubby holes and glove box. Just the door pockets to go.
The only problem I've had is the back piece for the glove box..... the supplied piece (3 in pic below) is for a flat surface and the back of the glove box isn't flat. I think it's because it's slightly different to a left had drive car and my kit does say it's for a right hand drive. The piece does fit with a bit of cutting, though not as well as the rest.
Here's pic of instructions, even includes small box to right of steering column which I didn't see on website.
I'll post more pics when I've finished
