Dj magpie
16
Want to fit boost , oil pressure and oil temp gauge which is the best way to run wires throu the bulkhead to engine lcr 2005 thanks
There's a grommet under the scuttle panel on the driver's side which I drilled through, ran wire/ hose through it into the cabin (can be a little fiddly getting a hold of it under the dash, but it is doable) and added a little sealer to keep it water tight once finished.
Reactions: mty12345
Haha have fun pal it's a pain of a job as said above but looks well, did mine 3 years ago thank god I had help though cause there ain't much room, where you mounting yours in the a pillar or centre vents.
I want to put a pod on dash but mean drilling/cutting the dash so probs just go with piller pod
