1.4 TSi ACT economy
Seriously?
1,244
837
Dunno how accurate the on board consumption indicator is, but more than happy with this:
Reactions: Wilkesy
Mr Pig
2,617
906
I've just filled the tank after running a tank in Eco Mode and driving as economy friendly as I can. Most of my trips are very short, it's a second car, but it was the same type of journeys as before so a fair comparison of Eco Mode and sedate driving vs Sport Mode and using the revs a bit more.
Previous tanks average about 37-38 mpg.
This tank was 40 mpg.
I suspect most of that whole 2 mpg was due to driving style and Eco Mode does pretty much feck all. Sport Mode from now on then...
Reactions: Tass
Seriously?
1,244
837
49.24MPG over the last tank for me. Measured, not indicated by the cars trip computer.
Sounds pretty good; I'm assuming that the on board computer is optimistic ( it's a VW group product after all.....o_O )
Anyone have any idea by how much ? 10-15%?
Glosphil
415
178
Gloucestershire
My previous car, an Octavia vRS diesel was just under 5% optimistic when calculated over 40K miles. My Leon 1.4TSi (150) FR over 5K miles is currently less than 1% optimistic.
Tass
33
9
So far I've discovered it's a difficult beast to drive economically. Because of the ACT setup it seems to use more fuel cruising in a higher gear with a light foot, than it does in a lower gear with moderate revs and ACT activating. Hence my economy figures don't seem to change much either when I'm being light-footed :/
I'm having to re-train myself not to change up and let the revs drop, but to always keep the revs around 1400-1700rpm (the lowest range that act will cut in)
I'll try doing a tank-to-tank comparison too and report back.
Reactions: Mr Pig
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
So you did 124 miles, and still had 'according ot the car' another 555 miles of range left in the tank? So a theorethical range of 650 miles from 50 litres.
Tass
33
9
I'd love it if it were true! 17 hours between fill-ups would put me somewhere in southern France before I needed to stop.
The tiredness alert feature would be going bonkers tho :D
Seriously?
1,244
837
Apparently so - which was one of the reasons I questioned the accuracy of the on board consumption indications.
Mr Pig
2,617
906
I'd like to see that.
I'll be honest, I don't understand the ACT system. It's not like you're turning the engine into a three-cylinder one. It's still a four-cylinder when running on two so the rotating mass is still the same. I would have thought that moving the car a certain distance at a certain speed would require the same amount of fuel irrespective of how many cylinders that fuel is being burned in.
Tass
33
9
It's apparently due to the inefficiency of petrol engines when supplying low torque. As I understand it, two cylinders supplying moderate pushing power require less fuel to be injected overall, than four cylinders sharing the same amount of work.
This 'self study program' for dealers explains it nicely
  • Self-Study-Program_1_4L_TSI_engine_with_active_cylinder_management_ACT.pdf
Reactions: Mr Pig
SuperV8
1,337
590
Yes - the total friction of the engine is the same, but by running on 2 cylinders at low load requirements those two cylinders are having to run at higher torque and are running more efficiently, converting more of the fuel into motion - most piston engines are most efficient around their maximum torque - the problem being at cruising speed they are nowhere near their maximum torque. All engines are basically over sized for cruising speeds to give us good acceleration and high top speeds.
Yes - a car moving at certain speed would require a certain amount of power, but the amount of fuel required to make the required power varies with the efficiency of the engine.
Tom.
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
Probably why 4 engine passenger planes are disappearing for 2 engine ones. I digress...Saying that, fiat's 0.9l Twin-Air (eg..2 cylinder) motor isn't more economical than 1.0TSIs.
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
I'd still rather have 4 engines, in case one stops there's more chance of staying aloft?
There's an airline joke, where a 4 engine plane lost an engine, and pilot assured everyone, it was ok, we would just be 1 hour late, then the 2nd went, and the pilot as calm as ever, said, no worries, just 2 hrs late, then the 3rd went, and captain said the same thing, then the passenger commented, 'man, if the 4th engine goes, we would be up here forever....
Reactions: SuperV8
GeoffGeoff
191
40
Getting 38-40 on a mostly dual carriageway 11 mile trip in sports mode with mixed driving on a 130 1.5.
mused to get 44 on my previous diesel same journey and similar driving...happy with 6nog loss going from diesel to petrol.
On a longer journey I had 50mpg in the Leon and max I ever had in the diesel was 60 and that was very gene driving so I’m happy with the change to petrol and no worries about dpf’s and other expensive diesel bits to go wrong.
