Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Hi lads need some help, can't seem to get my wing mirrors to fold in when I lock the car, went into car settings on display and tried that, but when press key fob, only locks doors, appreciate any help, thanks jon
Not all cars have that function. You can enable it with OBD11 but some cars just have a manual fold/unfold function which works of the door mirror switch.
From factory single press on fob locks car. If you press it a second time and hold the lock button mirrors should fold. You can code it so it folds on 1 press of the lock button which most ppl do
If your mirrors fold in using the toggle then it must be the windows that need resetting (honestly).
Holding the lock button would normally shut any open windows, as well as folding your mirrors. However if the system can't shut the windows it won't fold the mirrors. It's all to do with the anti-pinch system so you can't shut a window on someones, hand, arm, head etc.
So to find out which window needs resetting trying using the one touch close/open on each window. The window (or windows) that doesn't one touch open/close will need resetting. If you to a search for resetting windows on here, or check the manual you'll get instructions on how to do it. Involves something like opening the window and closing it and holding it closed for 10 seconds.
Just want to say thanks so much lads for your help, you solved it I pressed fob twice and held button and mirrors folded, this forum is great, just gonna see how to get them fold on single press when locking car,
Roof didn't close but guess that's cos don't have a sunroof , thanks again lads
1 - Module 09- Electronic control unit. Code (31347)
2 - Adaptation
3 - Access control 2 Up to MY16 or enter Spiegelverstellung From MY17 and later
4 - Funk spiegelanklppung modus - (Change value to Convenience operation via remote control key)
Press and hold the button to fold or unfold
5 - Funk Spiegelanklappen - (Change value to On)
If you also want to close with a single click instead of keeping the button pressed:
6 - Funk spiegelaklappung modus - (Change value to By look command via remote control key)
If you also want to appear in the car menu to activate or deactivate from the screen:
7 - Menuesteuerung funk spiegel anklappen - (Change value to On)
