Need help
Jul 21, 2020
Hi everyone.
I have a 2007 Leon 1.9tdi and need some urgent help.
The oil pressure light, engine management light, distubuter light, emissions light and "workshop now" are all on. Also when driving it won't go above 2500rpm and the rev counter isn't working. I was coming to a stop and the car cut out and had to be jumped to get it started, then when I went to drive again it just cut out.
I have changed the oil pressure sensor, crankshaft sensor, camshaft sensor and battery. Still the same faults
Any help will be appreciated!!
Legojon
I only wanted a remap
5,084
2,540
Hi, it prob won't go above 2500rpm cause it's in limp mode. Not sure on the 1.9TDI... but in the 2L petrol the oil pickup pipe tends to get clogged and cause low oil pressure. I assume 2007 is pre DPF?
Jul 22, 2020
hey,
i have a seat leon 1P manual not turbo, im hearing a ticking sound when the car is moving, the sound is from the front left wheel and it disappears as i use the clutch or when the car is neutral
any idea
Legojon
5,084
2,540
hey,
any idea
Hi, would have been better starting a new thread. From the sounds of it, could be chatter from the dual mass flywheel.
