NigelPatrick
76
They are both broken and need replacing. I need to know what the bulbs inside are called.
Many thanks.
Nigel, if you take the lamp out the model is stamped on the metal plate
Exactly, you will need to get in there eventually when you buy new bulbs if actually they have failed, so get in there now and see what these bulb types are, normally they will be a bulb+fitting/connector so better to see for yourself and not blame others when you buy in the expensive wrong model/type. Also visually and if possible check to make sure that they are O/C before just buying and fitting new ones.
