Sep 27, 2020
All
I'm looking to change the gearbox oil in my manual 184 TDi, as this is a sealed for life fill im struggling to find how much oil i will need. A vid on Youtube said it was 1.3 litres, this was admittedly in a Mk7 Golfd GTi, but i thought it would probably be similar if not the same. I then found referance to 2.1 litres in a workshop manual for the Ibiza. Before i buy the oil can anyone answer this question definitivly?
2.3 litres if completely disassembled and 2.1 litres if drained according to the workshop manual.
There is a manual for the 6 speed manual box. Section 3.2 for the volume quantities, Section 5 for the drain/fill procedure.
In addition, Lidl were selling a 12v pump for automotive oil removal takes power from the battery - didn’t look at it in any great detail, but might speed the job up.
Great stuff, thanks for that.
Reactions: Woody_72
Is 2.3 litres the capacity of the dsg gear box?
The OP referred to ‘manual’ gearbox, so the answer is no.
If you use the links that I posted, there are different workshop manuals for the respective manual and DSG gearboxes (although don’t think that there is a 7sp one for newer Cupra models).
You will find the oil capacities there.
