Oct 15, 2020
18
Birmingham
hi everyone need some help please... 2006 Leon FR TFSi. turn ignition on and nothing!!! I get side lights, interior lights, indicator and very low/faint sounding alarm wirl with indicators flashing. No; Central locking, ignition lights, Radio, Fuel pump Prime nothing?
i've swapped out the Terminal 15 relay still nothing.
i have just noticed the aux power supply on centre console has a plug snapped off & lodged inside. ill sort this out in the mean time any help would be amazing Thank you all in advance.
OK Update... Removed item from aux supply. no change. I have an AUTEL Scanner & it can not communicate with the Gateway, but it is telling me that there are faults in the; Central Electrics but it can not enter to interrogate the issues.
Not sure if the snapped off plug is misleading, but worth checking the fuses and relays under the bonnet. Previously the YTS kid wired a battery the wrong way, similar symptoms. Luckily the fuse saved the ecu. Can't remember which one it was tho.
LOL yeh all fuses & relays are good... im getting power at the steering co;um large multi plug but still no dials or start up... ive also noticed the radio display is very faint almost invisible.
I sure hope this helps someone in the future... OK sorted my issue, it was a faulty steering Module that lives under the steering wheel. there are 2 multi plugs to remove & its attached to the column via 2 hidden clips (1 at the rear & 1 internal that you need to release with a thin screwdriver or pick shaft)
Seat quoted over £300 for the part and a further £150 plus to code it.
well i bought one on Ebay (matching the serial number) for just £25.
