I Need help Checking for pcv failure
Matty92
9
Hi, I have a leon mk2 2008 2.0 tfsi 197bhp DSG.
I have been having poor starting and rough idling and fuel consumption is getting worse. I've heard pcv can be a cause and apparently you can check by taking off your oil cap off, I done that and the car cuts out in seconds is that an indication that its failing or is it working fine?
Reactions: WeeGmac
Matty92
9
Pretty good indication something is wrong.
Would start by changing the PCV and diverter valve (if not already done).
I haven't changed them, but will definitely try them thanks,
should the engine be running still when the cap has been taken off and has a bit suction on the oil cap too not strong suction but has a bit of a pull on it
