Hickery1995
154
81
Can someone recommend some decent spacers to fit my 2019 Cupra, and what size I'd be best going for? Thanks.
Sent from my SM-G975F using Tapatalk
If you use the search function this has been covered hundreds of times over various different posts....
but to not be a **** I’ll answer your question
supplied byone of the site sponsors,12mm front 15mm rear
Cheers mate, haven't been on here in ages and completely forgot I could have just searched this , thanks
Reactions: Nicholas Ellis
Yeah, just click 'front and rear' on my post. The spacers I used are half the price of some and are TOP quality.
For standard wheels it's radius bolts not conical too?
What did you do about your locking wheel nut?
Sent from my Pixel 5 using Tapatalk
When you order you say whether you want conical or spherical and they send longer bolts in the kit, obviously we want spherical. I chucked my locking bolts years ago, not worth keeping.
McGard locking wheel bolts come in both conical (aftermarket) and radial (OEM) versions. Thread pitch is M14 x 1.5, 17mm hex, length of bolt will be as per supplied with the spacers, but standard length is 27.5mm or 28mm.
Reactions: Dannnnn
