Where is the button to send it to the car. I cant seem to find that.Yes you can using the SEAT Connect app. Go to the map icon, find where you want to go and send to car. Works a treat!
Same here I can save a location as a favourite or there’s buttons to navigate to the car itself or the destination I’ve searched for which just opens Apple Maps.Where is the button to send it to the car. I cant seem to find that.
Does the car need to be on for this button to appear?View attachment 23302
Just press the use in vehicle button. It then appears as a destination on the Nav in the car
Not on mine, app is running on an iPhone but I would have thought this was standard, it looks like it’s a main use case.Does the car need to be on for this button to appear?
How did you find this out? Could they not enable the feature. It is quite disappointing.It seems the first versions do not have support for this. At least: my 08/2020 doesn't have this.
I do not have this option in the app.How did you find this out? Could they not enable the feature. It is quite disappointing.
Yep - absolutely no issues opening the boot.Mine is the same, I cant unlock the front doors using the touch point. I can open the boot without using the key though.
What's strange is if the car is locked and I walk up to it, the front doors wont open when I use the handle to unlock. If I go the boot and open that, then close it and walk back round to the front door it will then register and unlock the car. Is yours the same? If I drive the car and then get out it will lock fine using the touch on the handle.
Think it's the power saving induced sleep mode of Kessy that they haven't programmed correctly as I've mentioned before. My Ateca if left for a few days the passenger door handle side goes to sleep, you walk to the drivers side and open from there. Wandering round to the back sensor in the boot is waking the system up. That's what people report. I've never tried that with mine since the drivers side always let's me in (worked like that for 4.5 years). The Leon 4 fault which the dealer can fix from the thread is both sides are permitted to go to sleep in the Kessy power saving mode - it's a software bug where the engineers have left both sides to go into power saving. The walk round the back is picked up by the boot sensor for people who get in that way with the bug .Yep - absolutely no issues opening the boot.
Havent tried going from door to boot to door but will tomorrow!
I have mk3 and noticed that with heated seats sometimes they are still switched on (same setting) after a short stop, whereas after a longer break they're off.
That sounds like it's by design - obviously mk4 vs mk3 and heated seats rather than rear window. But same principle probably applies.
My digital cockpit should look like this:
but now and then when starting the car it has been changed to this instead:
Anyone else having this issue?
It does not happen so often for me, but it is irritating...
