qbait
13
I have the possibility to choose assistants so I'm wondering which ones are worth extra paying and which ones are only disturbing:
Comes as standard:
- Park assist
- High beam
- ACC
Extra 500GBP:
- Side assist
- Lane Assist
Extra 100GBP:
- Traffic jam assist
Shall I stick to standard assistants, or do others work well and are worth paying?
Lot of people complained about lane assist - it is on by default and it will slightly nudge the wheel if it feels you are going over the line. It's not a super strong force but if you drive where road lines are bad or you do a lot of corner cutting, you may find it annoying. I personally don't mind it. My guess is that without lane assist you cannot use ACC lane holding - which can be useful if you are in boring commutes often.
Side assist - I guess this is help when reversing from a parking space. I find this very useful as it will signal and in the end brake if needed if it sees a car/pedestrian and you are not stopping while reversing. Again some people don't like this as the system is slightly over eager but I prefer that to hitting someone.
Traffic jam assist - not sure what this is? Perhaps some kind of navigation option?
Reactions: Hampa1 and qbait
I think you are going to get a huge mix of answers on this!!
My car has all of those and find them all pretty useful. The lane assist I could probably do without but don't find it obtrusive.
If you have the cash I would go for it as they are nice to have.
Sent from my Pixel 5 using Tapatalk
Reactions: jcbmally and qbait
Traffic jam assist is the cruise control option which will just follow the speed of the car in front from standstill up to whatever speed you have it set at.
Reactions: qbait
Most work well ut you need to be careful with Lane assist - it gets confused pretty easily on some roads and also ACC - you can set it to stick to the road speed limit but it sometimes gets MPH and KPH confused which can cause the car to brake unexpectedly. Not good. Overall though worth having as I'm sure there will be a fix along soon for the bugs.
Reactions: qbait
Even Blind spot detection?
That's harmless, but I was driving without it for more than 20 years, so I could live without it another 20. I still check the mirrors and turn to look. Problem with all these gagdets is, that they are dumbing down and if you drive other cars without gadgets, you may forget to check the road yourself.
Traffic assist also follows the road layout and will slow down/speed up according to the road layout. So a sharp bend it will slow etc
Would also like to be able to turn lane assist off. Just got my car (2 days) ago, was driving down the motorway, with ACC switched on ... in the middle lane, trying to overtake a car .. .and ACC started slowing the car down, as it "sensed" the car on the inside of me ... I had to press the accelerator to not slow down
Could not figure why it was doing this. What seemed to fix it, was to turn off lane assit, now it does not sense the car on the inside
Is this caused by Lane Assist or something else?
It’s a known bug. I believe the car thinks it on EU roads and that you are undertaking. VW group are working on a fix. For now you can turn it off in the menu settings. lane assist gets confused easily too especially on wide slip roads where it doesn’t know which white line to follow. Generally as long as you indicate lane assist is ok.
That makes sense, hopefully they fix. It seems I cannot turn it off permanently though, only on each trip
YYou
You can't do anything about it, except stop using ACC. Patch was supposed to be released in December, check with dealership. Lane Assist has nothing to do with it.
Raised today that lane assist does not affect (as you said). At the moment the ACC doing this, really does feel dangerous ... Doing 70, going to overtake and then suddenly the car slowing down, sometimes quite a bit depending on how slow the car going on the inside .. is everyone having the same problem? Does the update come down through the air (sure I got an update when I first got the car) or is it a dealer only? My car is running 1804
Reactions: jcbmally
