Heated steering wheel
andyjj
13
On the first really cold day since I have had my Leon PHEV Xcellence, I pressed the switch on the steering wheel to switch on the wheel heating.
No heating, but it does change the digital cockpit display !
Delving into the Infotainment, I can switch the heating on, but the physical switch doesn't work.
Anyone else with the same issue ?
Keith Roberts
64
14
It’s the very bottom right switch. Double press heated wheel on next press heat 2 press again heat 1. Next press off. There’s a icon appears in the central display that indicates the temperature levels. If you are pressing a button and the digital cockpit changes I would assume it’s the view button.
cheers
andyjj
13
Now that's embarrassing 🤭
I had persuaded myself I was pressing the heated wheel switch as it looked like a wheel. It was the Driver Assist button (not the view button) !
Oops :ROFLMAO:
