Locating the Speakers fuse - Seat Ibiza 2012
Apr 13, 2022
10
Does anyone know where the left-hand door speakers fuse could be located? They still do not seem to be working.
I have tried replacing the hazard panel as the aux was faulty.
L and R Audio balance. seems to be in place.
I can only think it can only be:
Wiring issue or Fuses.
I am not even sure how to look at the wiring on the back of the unit.
Any Support would be much appreciated.
Seriously?
1,255
840
I think you'll find that speakers don't normally have specific fuses; if it's a door speaker that isn't working I'd suspect a broken wire in the harness where it passes between the A-pillar and the door.
rafletcher
531
214
This. Speakers are passive devices that aren't fused. If it's just the one then it's a failed speaker, bad connection or broken wire. If it's all the LH speakers the amp's probably toast.
Apr 13, 2022
10
Does anyone know of ways I can test the wires/remove the door panal or the cost to have it repaired?
