HelloPitty
38
10
Hello.
I have been seaching the web to try to find out the model / reference of the wheels in the picture attached, which belongs to a Seat Ibiza Cupra 6L, but I can't find it anywhere.
I need the wheels center cap that are in the following picture, and I am not sure of the correct measures.
Hello.
Don't you have the OEM code inside of the rim? Have you tried searching for that?
You sure it's 6L OEM? These are the only rims I see for Ibiza 6L.
Some of them have that center cap which is the same for 2 rims. To me, it looks like titanium gray which has the following code:
6L0601149E SGK
I hope this helps you.
6L0601149E SGK
By OEM you mean original? They were fixed in a specialized shop and I'm not sure if the color is original. In the image you sent, I'm not sure if these rims are there. I can't see an exact match.
They are older wheels i don't know what model designation they are but from 2004-2008 roughly
I'm already in talks with 2 persons. One has the center caps to sell and the other has an Ibiza FR with these same rims. If the owner of the car is willing to take out the caps and check the reference and/or measure the diameter, I can then compare with the ones the guy that has them to sell and check if they fit in my rims!
So I've found your wheels. The code is 6L0601025P. The center cap for these wheels is 6L0601149E.
Took them right from the parts catalogue.
  • Love
Reactions: HelloPitty
