Yes did mine pretty easily, just pull firmly on the cover, it will come away far enough to run the cable behind and down to the top of the dash, then remove the side cover where the airbag switch is, you can then run the cable over to the top of the fuse panel. The hardest thing to do was getting the glove box to drop so I could get to the fuse panel itself, it's easy enough to unhook the dampener, but pressing the clips on the box to get past the stops was not fun.
Hi, did you pull it away on the window side? Not sure
how to route the cable at the base of the A pillar from window side without removing the A pillar trim ?
