Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Anyone? Are anyone else's settings not stored ? e.g. the steering wheel is always heated when I start the car, even if I disable it. Same with lane assist.
The vehicle's battery may be weak. Such problems can occur in many electronic devices when the battery voltage is low. If there is no problem in your electrical system, have the battery values measured.
Two things -
1. I took my Born in last week. The guy explained that lane help etc reverting to ON was by design for safety. He also said no s/w updates were available as far as he was aware.
2. Then I seemed to get a s/w update when I was driving days after. I need to check the version!
A lot of settings will revert to a factory default setting (lane assist, start/stop etc etc) unless you deliberately code them to something else using OBDEleven.
If it develops a fault because of your coding, yes. But they can't deny a warranty claim if (for example) you coded out the lane assist and you develop a fault with the exhaust.
Is there a way to make the option for (for example) lane assist more easily accessible? I am developing muscle memory from switching it off each time I drive but would prefer if it was easier
