Wing mirror lower in reverse
chrislocalboy
24
Has anyone figured this out? The instructions in the manual appear to be absolutely wrong as I've followed them step by step about 5 times, they don't work and to be honest they don't even make sense (it's the passenger mirror that lowers but it tells you to adjust the driver side ('R')
I've got it to lower but only when I turn the knob to 'L' the option in the infotainment system seems to suggest this should happen just by me putting the car in reverse?
axeriano
27
12
Latvia
I think "adjust the driver side (R)" is a mistake from LHD version manual. :D
1. You need to set your mirror joystick to L.
2. Adjust your mirror to position when you normally drive.
3. Engage Reverse.
4. Lower your mirror for driving in reverse.
5. That's all. Remember, that mirror will not return to its normal position until you drive more than 15km/h or lock your car.
chrislocalboy
24
3. Engage Reverse.
Thanks buddy... Ok so just tested it and I believe everything you've said is correct (need to test the 15km/h thing still) but this only happens if I leave the selector knob in 'L'... If I leave it in the central position and engage reverse nothing happens, but engage reverse with it in the L position it does indeed move down
axeriano
27
12
Latvia
Yes, that's how it works
That's correct, as it gives you the option of being able to see what's behind you, or see the curb
Reactions: chrislocalboy
Lehn
22
18
34
Denmark
And the lowering of the mirror is connected to the seat adjustment profile if you have electrically adjustable seats.
