DEAN0
Old Git
Feb 1, 2006
5,447
Preston - UK
Hi Guys - My son has an issue with his 184TDI
The EML and the flashing glow plug light are on. Car is in limp mode.
Code read is
5244 - Fuel Pressure Sensor ( G247 )
P0193 00 ( 175 ) - Short to plus
MIL ON - confirmed
We have changed the fuel pressure sensor - still same issue
We have tested the fuel pressure sensor plug connections ( battery voltage was 12.65v ) - ignition on - engine NOT running
Pin 1 to battery positive - measured 7.65v ( should be battery voltage )
Pin 2 to ground - measured 5v ( should be battery voltage )
Pin 3 to ground - measured 0.01v ( should be 5v )
We have tested all three wires from the Fuel pressure sensor back to the ecu - no shorts and all show continuity.
Has anyone had a similar issue and what fixed it ?
We were hoping to find an issue with the wires or connectors.
I had similar issues with my 184 a few weeks ago but got code P0191 and replaced the sensor. It seems to have solved it for me though.
Sounds like yours is more wiring related and I don't know what to suggest. Hope you get it sorted.
Reactions: DEAN0
Code read is
MIL ON - confirmed
For a P0193 fault of the fuel pressure sensor I get:
1: Check supply voltage pin 3
Turn the ignition on. Measure the voltage on pin 3. Should be between 4.8 and 5.2 V
2: Check ground connection pin 1
Turn the ignition on. Measure the voltage on pin 1. Should be between 0 and 0.2 V
3: check the connectivity of pin 2:
Measure the resistance between pins 2 and B 55 (E1 Engine control unit). Should be less than 1 Ω
Cheers for the suggestion.
Just for clarity - can you confirm which way the pins are numbered ?
The diagrams on line show this :
BUT
The connector on the car has 1 and 3 the opposite way.
BUT
I don't have a connector diagram.
I would follow the labeled numbers on the actual connector.
Voltage should be checked between the pin and an earth - not the battery positive.
Been to car to do some measuring.
Ignition ON
Battery Voltage 12.57v
Fuel Pressure sensor plug disconnected.
Connector labelled Pin 1 ( Brown/Red wire ) to battery negative = 0.019v
Connector labelled Pin 3 ( Yellow / Brown wire ) to battery negative = 5.018v
Connector labelled Pin 2 ( Yellow / Grey wire ) - continuity test to ECU connector - 0.2ohm ( same reading as just touching the multimeter probes together )
Based on the above - I would say the wiring to the G247 fuel pressure sensor is good.
Ignition ON
For me that confirms you wiring is good - and the fault is probably with the sensor - as long as you're sure the connecter is connecting to the sensor? I have had connectors which were not, and a small tweak of the contacts fixed it.
Fuel pressure sensors are just strain gauges. You can check their function - but really need need to scope the output signal when changing pressure. At this point I would be fitting a new sensor.
Cheers.
It has already had a new sensor - Bosch one.
Will try tweeking the contacts.
Cheers.
Ah yes, I see from your first post.
When I put the fault code "P0193 - Fuel pressure sensor 1 circuit high" in for my 184tdi it shows:
Fuel pressure control valve
Fuel metering solenoid
Fuel pump
Some further testing:
Fuel pressure control valve:
1: Resistance between pins 1 and 2 should be between 1 and 5 ohms.
2: Ign on, measure voltage on pin 1 - should be between 11.5 & 13.5v
3: Measure the resistance between pins 2 and B 45 (E1 Engine control unit). Should be less than 1 Ω
Fuel metering solenoid:
1: Ing on, voltage on pin 2 should be between 12 & 14.4v
2: Disconnect the fuel metering solenoid. Connect pin 1 to the negative battery terminal. Briefly connect pin 2 to the positive battery terminal. The solenoid should 'click'
3: Measure the resistance between pins 1 and B 60 (E1 Engine control unit). Is it less than 1 Ω?
Fuel pump:
1: Measure the resistance between pins 1 and 3 (E9 Fuel pump control unit). Should be less than 1 Ω
2: Measure the resistance between pins 2 and 2 (E9 Fuel pump control unit). Should be less than 1 Ω
3: Measure the resistance between pins 3 and 1 (E9 Fuel pump control unit). Should be less than 1 Ω
4: Measure the resistance between pins 4 and 1 (O8 Grounding point 75). Should be less than 1 Ω
UPDATE - sorry for delay but life/work got in the way.
The measurements above all checked good.
Bought a complete fuel rail with fuel pressure sensor and fuel pressure regulator from a running CUPA engine.
Fitted fuel rail and finally got the flashing glow plug light off.
Took it in to a local specialist and had a forced static regen done on the DPF ( was 42g at start - finished at 3g after 40 mins )
Car seems to run normally now with the exception of the idle speed that seems to fluctuate slightly ( it used to be rock solid at appx 800rpm )
Reactions: Compo1 and SuperV8
