Runing cables through firewall
gsila
Is there any easy accessible through holes/gromets in the firewall to run a couple of wires throu firewall.
And did anyone sucesfully add circuits in stock engine bay fusebox?
RADIOTWO
516
98
North Derbyshire
It depends on what you want power for ! the best way to get power is just use a piggy back and tap into
a fuse
gsila
I want to install an air horn.
So i measured operating current of air compressor for horn and it draws 15-25 A (open hose or closed hose). I want to keep stock horn functional and just add a fuse, relay and a switch for airhorn... airhorn activated(both horns wil be working) when deactivated... only stock horn will be working.
andylong
494
Put a relay in the current horn circuit and then just wire the air horn from the engine fusebox. No need to go through the firewall
andylong
494
Wait, you want to turn the airhorns off?
Ignore the above then and don't get caught.
RADIOTWO
516
98
North Derbyshire
Ok I get it, I don't know of any where but there must be a rubber grommet that would allow you to get a wire through, you should get away with just one wire and you could do it as the single wire goes to the switch and then to earth, but just make sure you fuse it
